Madroadahead
#1 Posted : Tuesday, October 21, 2014 10:07:24 AM(UTC)
Madroadahead
My house was build in 1967 and still has the original GE working wall oven. I don't use the clock or the timers on it but recently the clock has started to make a fairly loud rattling/buzzing noise. I'm wondering if there's a way to pop off the upper panel with the clock and dismantle the clock so it will be silent. Any suggestions? Thanks!
#2 Posted : Wednesday, October 22, 2014 1:30:52 AM(UTC)
Unplug the unit or flip the breaker off if it is hard wired.
Remove the rear upper cover so you can get to the timer.
You should see a motor mounted to the timer, just disconnect it.
Be sure to tape up and position the timers power wires where they cannot short to anything.
Madroadahead
#3 Posted : Wednesday, October 22, 2014 6:42:17 AM(UTC)
Madroadahead
Great! Thanks!
