Phractal33
#1 Posted : Sunday, January 5, 2014 6:10:04 AM(UTC)
Phractal33
My Amana Electric oven Clock went out and I no longer have control with the dial for oven temp. The Oven works (No Broiler), but only in an ON/OFF Capacity.
All of the range burners work fine and have full control, also the Oven Light still works fine. After a bit of research I am under the conclusion that the Electronic Range Control board is out, but just wanted to get some guidance before I pull apart my oven to check continuity and drop a couple of hundred dollars on a replacement part.
#2 Posted : Monday, January 6, 2014 1:26:21 AM(UTC)
Parts for ART6113WW - AppliancePartsPros.com
See the attachment for your tech sheet.
Sorry but I do not understand the following.
[COLOR="Blue"]My Amana Electric oven Clock went out and I no longer have control with the dial for oven temp. The Oven works (No Broiler), but only in an ON/OFF Capacity.[/COLOR]
Note that it does sound like a control board problem as:
A high limit thermostat problem would kill power to both elements.
A oven sensor problem should not cause the clock/control board to go off
File Attachment(s):
ART6113.pdf (168kb) downloaded 2 time(s).
