sell.pete@gmail.com
#1 Posted : Monday, December 28, 2009 7:01:29 AM(UTC)
sell.pete@gmail.com
Recently I installed a garbage disposal. Of course reading the instructions for such a simple task wasn't nescessar. Opps...the plug for the dishwasher drain wasn't removed and the floor was covered with water. (1 time) Removed plug and everything seemmed fine, but the dishwasher seems louder than before while the pump is running. Is it possible that the pump was damaged due to the pressure? How likley may this be or am I just imagining increased noise due to mu mistake?
#2 Posted : Monday, December 28, 2009 3:49:58 PM(UTC)
On which part of the cycle it seems to be louder? What kind of noise is it?
sell.pete@gmail.com
#3 Posted : Monday, December 28, 2009 6:55:48 PM(UTC)
sell.pete@gmail.com
It is when you first start the dishwasher. It seems to be only when the pump is running. During what I would call the fill cycle. The other thing I noticed is that when the unit drains it doesn't seem to have a great deal of fource. Maybe this is normal as well.....I really never payed attention before.
sell.pete@gmail.com
#4 Posted : Monday, December 28, 2009 6:58:10 PM(UTC)
sell.pete@gmail.com
#5 Posted : Tuesday, December 29, 2009 2:05:46 PM(UTC)
If it is kind of a vibrating noise then it can come from the water shut off valve under sink. It is very common source of such noises. I do not think the improper garbage disposal installation can cause damage to the dishwasher.
Remove all screens inside the dishwasher and make sure there are no any foreign objects.
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Sub-Zero new model makes loud noise (Refrigerator & Freezer Repair)
by Guest 5/3/2024 7:49:55 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
Kenmore 110.47566601 makes loud spin noise (Washer Repair)
by Guest 4/6/2024 7:42:40 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
Speed Queen Washer makes random squeaking noise (Washer Repair)
by Guest 2/10/2024 7:29:00 AM(UTC)
Control panel goes dark and loud clicking noise (Refrigerator & Freezer Repair)
by Guest 2/6/2024 12:57:10 PM(UTC)
Slow agitation and spin with clicking noise in bottom end of machine (Washer Repair)
by Guest 1/13/2024 12:19:08 AM(UTC)
Noise during rotation of dryer drum (Dryer Repair)
by Guest 1/5/2024 11:22:05 AM(UTC)
LG dishwasher loud clicking noise after cycle completes (Dishwasher Repair)
by Guest 10/29/2023 6:43:16 AM(UTC)
Samsung Front Loading Washer - Noises Even When Manually Spun (Washer Repair)
by Guest 10/18/2023 3:20:35 PM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
