Dana Bender
#1 Posted : Sunday, December 27, 2009 1:35:18 PM(UTC)
Dana Bender
When we opened the back of the dryer there was no thermostat. Is that common? The dryer was working before and we installed a new heating element and it still doesn't heat. We then bought a new Thermal Cutoff Kit #279816 and hints on installing this or should be bypass the thermostat since there is not wire from the wiring harness on the factory assembly.
sidfink43
#2 Posted : Monday, December 28, 2009 12:18:28 PM(UTC)
sidfink43
I do not completely understand your post but let me say this.
You dryer should have a thermal fuse and operating thermostat on the blower housing, and a high limit thermostat and a thermal cutoff on the heater housing.
If you have no operating thermostat on the blower housing or a high limit thermostat on the heater assembly and no way to put on on correctly you need to contact Whirlpool and get them to replace the machine, because even if it is out of warranty it is a major manufacturing defect and a major safety issue.
mikeburn
#3 Posted : Monday, December 28, 2009 1:59:02 PM(UTC)
mikeburn
thanks,
i checked all of the thermostats, and they were all closed 3 on the heating element housing and 1 on the blower. I held the idler in a position so as it tripped the belt switch and ran the dryer to check for voltage (front off total run operation just no drum) I checked voltage on the left side of the element 1 lead to the element the other lead (meter) to the base of the dryer got 110 same with the other side,same I put the leads between both sides of the element.no voltage? Am I testing this correctely? the element is brand new and good...........
sidfink43
#4 Posted : Monday, December 28, 2009 4:29:38 PM(UTC)
sidfink43
Check your new heater for continuity, should be between 7 and 12 ohms.
Then check and clean the connections to the heater element, and make sure they are very tight.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
