my GE side by side refrigerator GSS22JFPAWW defrost every 4 or 5 days"
This sounds close to normal for an adaptive defrost control to be defrosting. Is there a problem you have with it defrosting this often or is this too often.Or are the contents defrosting also. This could be a defrost thermostat problem. (not shutting off heater when it get too warm.)
Originally Posted by: woodchuckie  This sounds close to normal for an adaptive defrost control to be defrosting. Is there a problem you have with it defrosting this often or is this too often.Or are the contents defrosting also. This could be a defrost thermostat problem. (not shutting off heater when it get too warm.) Thanks for the comeback, I did replace the defrost thermostat, when it goes into defrost it stays ther for up to 10 hours and the temperature will reach 50 deg. then it goes back to a normal cycle, the defrost thermostat might be bad. will replace again hope this time it will work.
