I have a Kitchen Aid KUDM01TJBS0, ser # FL1109352.
The heavy cycle starts but does not finish. None of the other cycles either light up or work. After heavy cycle runs for about 10 minutes then stops. The rinse and normal lights start flashing. when I hit the cancel button to drain, it flashes and doesn't drain. Help, please.
Gene,
The color of the panel is black. Do you also provide install instructions?
Sorry for the delay. - The control panel Part number: AP3133651
Open the door and remove the screws around the inner door panel. Remove the inner door panel and you'll see what to do next. Gene.
