blinking lights are soak and scour, drying, off,4,6hr .Changed control board no change.Does anyone have any idea what could be causing this?
Here are your parts Parts for Whirlpool DU1055XTVT1 Dishwasher - AppliancePartsPros.comSee the attachment for the tech sheet. Could be a control panel (keypad) problem. Since there are a number of lights blinking that do not have a key it sounds like a problem with the circuit paths for the LED's. Unfortunately they do not show these in the tech sheet. I would still check the keypad with a meter just to see if something comes up bad. |
THIS FORUM IS DEAD!!!!!!! |
