ngldds
#1 Posted : Tuesday, December 15, 2009 3:33:28 AM(UTC)
ngldds
Dryer stays on at the 10 minute mark and just keeps running for hours. Doesn't get too hot as heat cycles on and off
#2 Posted : Tuesday, December 15, 2009 4:02:46 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...heet%20-%20W10035270.pdf
Check out the moisture sensor (page 10), if the unit runs OK in timed dry.
Could be that it just needs cleaning, re: the unit thinks the clothes are wet even when they are dry and so does not advance the timer.
ngldds
#3 Posted : Tuesday, December 15, 2009 4:28:08 AM(UTC)
ngldds
Thanks Denman. I am/was pretty sure the moisture senser is the problem but do not know how to check same. Unit is clean.
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
Whirlpool dryer stays on high heat (Dryer Repair)
by kjv42 11/6/2013 5:09:46 AM(UTC)
Kitchen Aid dryer stays on lowest temp whichever dial it is on (Dryer Repair)
by OrikKvisa 10/11/2010 11:43:49 AM(UTC)
Whirlpool Gas Dryer stays on for hours (Dryer Repair)
by xcalvinx 5/14/2009 9:21:30 PM(UTC)
