Dryer stays on at the 10 minute mark and just keeps running for hours. Doesn't get too hot as heat cycles on and off
Here is the tech sheet http://www.servicematters.com/d...heet%20-%20W10035270.pdfCheck out the moisture sensor (page 10), if the unit runs OK in timed dry. Could be that it just needs cleaning, re: the unit thinks the clothes are wet even when they are dry and so does not advance the timer. |
THIS FORUM IS DEAD!!!!!!! |
Thanks Denman. I am/was pretty sure the moisture senser is the problem but do not know how to check same. Unit is clean.
