vabshire
#1 Posted : Sunday, March 9, 2008 7:42:36 AM(UTC)
vabshire
My washer is constantly getting off balance during the spin cycle. I think it might be the springs under the tub but I am not sure and I cannot find a diagram. Can you help?:confused:
#2 Posted : Sunday, March 9, 2008 11:44:23 AM(UTC)
Pull off front panel and check for white shavings under the tranny. If so, go to my snubber replacement article in the general talk section.
vabshire
#3 Posted : Sunday, April 20, 2008 7:26:55 PM(UTC)
vabshire
Are you talking about metal shavings? If so, there are not any under the washer.
#4 Posted : Monday, April 21, 2008 2:21:37 AM(UTC)
Look for white plastic shavings. Set the washer to spin and open lid, push in the lid switch, and try to hold the basket. If easy to stop the basket from turning, you probably have a worn snubber ring.
Kenmore 11028132411 Washer Spins Off Balance and Goes Back to Rinse mode (Washer Repair)
by Guest 9/29/2022 10:45:15 AM(UTC)
WTW5000DW off balance during spin (Washer Repair)
by chouseal 5/20/2019 5:13:14 AM(UTC)
Off balance spin (Washer Repair)
by Marcumj 12/5/2017 9:17:13 PM(UTC)
Whirlpool Soft II Off Balance After Pump Replacement (Washer Repair)
by FloozyALaMode 5/2/2017 1:08:36 PM(UTC)
washer goes off balance during spin cycle (Washer Repair)
by rgarza47 7/21/2016 10:08:19 AM(UTC)
Washer Off Balance (Dishwasher Repair)
by treepm 7/30/2015 4:22:01 PM(UTC)
Off Balance Washer (Washer Repair)
by jenn_luvs_jeff 10/28/2014 6:26:40 PM(UTC)
Kenmore washer, off balance during spin cycle (Washer Repair)
by astro46 2/26/2014 11:16:34 AM(UTC)
Amana Gas Dryer - Off balance and rattle (Dryer Repair)
by ericn222 1/2/2014 8:17:58 AM(UTC)
Off balance and squeaking during spin cycle. (Washer Repair)
by mahohmei 9/29/2013 1:36:50 PM(UTC)
Kenmore stackable washer off balance (Washer Repair)
by bikerhaven 4/1/2013 4:41:53 PM(UTC)
Washer will not stop when off balance (Washer Repair)
by hwichhart 1/22/2013 8:51:03 AM(UTC)
washer making a loud noise and off balance during spin cycle even while empty (Washer Repair)
by drew2ginn 10/23/2012 6:13:52 PM(UTC)
GE front load washer smokes and sounds like the drum is off balance!! (Washer Repair)
by Idahogirl15 7/1/2012 2:36:19 PM(UTC)
washer tub is off balance and not secure (Washer Repair)
by andrea ochoa 1/5/2012 1:56:52 PM(UTC)
