vabshire
#1 Posted : 17 years ago
vabshire
My washer is constantly getting off balance during the spin cycle. I think it might be the springs under the tub but I am not sure and I cannot find a diagram. Can you help?:confused:
#2 Posted : 17 years ago
Pull off front panel and check for white shavings under the tranny. If so, go to my snubber replacement article in the general talk section.
vabshire
#3 Posted : 17 years ago
vabshire
Are you talking about metal shavings? If so, there are not any under the washer.
#4 Posted : 17 years ago
Look for white plastic shavings. Set the washer to spin and open lid, push in the lid switch, and try to hold the basket. If easy to stop the basket from turning, you probably have a worn snubber ring.
Kenmore 11028132411 Washer Spins Off Balance and Goes Back to Rinse mode (Washer Repair)
by Guest 2 years ago
WTW5000DW off balance during spin (Washer Repair)
by chouseal 6 years ago
Off balance spin (Washer Repair)
by Marcumj 7 years ago
Whirlpool Soft II Off Balance After Pump Replacement (Washer Repair)
by FloozyALaMode 8 years ago
washer goes off balance during spin cycle (Washer Repair)
by rgarza47 9 years ago
Washer Off Balance (Dishwasher Repair)
by treepm 10 years ago
Off Balance Washer (Washer Repair)
by jenn_luvs_jeff 10 years ago
Kenmore washer, off balance during spin cycle (Washer Repair)
by astro46 11 years ago
Amana Gas Dryer - Off balance and rattle (Dryer Repair)
by ericn222 11 years ago
Off balance and squeaking during spin cycle. (Washer Repair)
by mahohmei 11 years ago
Kenmore stackable washer off balance (Washer Repair)
by bikerhaven 12 years ago
Washer will not stop when off balance (Washer Repair)
by hwichhart 12 years ago
washer making a loud noise and off balance during spin cycle even while empty (Washer Repair)
by drew2ginn 12 years ago
GE front load washer smokes and sounds like the drum is off balance!! (Washer Repair)
by Idahogirl15 13 years ago
washer tub is off balance and not secure (Washer Repair)
by andrea ochoa 13 years ago
