hugo
#1 Posted : Tuesday, December 1, 2009 8:50:50 AM(UTC)
hugo
washing mechine over flows water will not stop
sidfink43
#2 Posted : Wednesday, December 2, 2009 5:42:47 AM(UTC)
sidfink43
If the water will not stop when the machine is off, replace the water valve assembly.
If the water will stop when the machine is turned off, check the tube running from the tub to the water pressure switch. It is probably obstructed.
If you need more info please post your full model number and the results of your checking the above.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
