hugo
#1 Posted : 15 years ago
hugo
washing mechine over flows water will not stop
sidfink43
#2 Posted : 15 years ago
sidfink43
If the water will not stop when the machine is off, replace the water valve assembly.
If the water will stop when the machine is turned off, check the tube running from the tub to the water pressure switch. It is probably obstructed.
If you need more info please post your full model number and the results of your checking the above.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 9 months ago
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 10 months ago
GE Top load washer not draining (Washer Repair)
by Guest 10 months ago
Washer won’t spin with load (Washer Repair)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 10 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 10 months ago
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 10 months ago
GE Profile Washer not draining and water not hot (Dishwasher Repair)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 10 months ago
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 10 months ago
Whirlpool duet washer front load (Washer Repair)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 11 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 11 months ago
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 11 months ago
GE washer grinding noise (Washer Repair)
by gefixin 11 months ago
