Effiemae
#1 Posted : Monday, November 16, 2009 10:04:00 AM(UTC)
Effiemae
Dryer has power as light comes on, but it does not run. When timer set no tick tick noise and it will not start.
#2 Posted : Tuesday, November 17, 2009 7:11:57 AM(UTC)
A Model Number may help others help you !!!
Effiemae
#3 Posted : Tuesday, November 17, 2009 8:24:44 AM(UTC)
Effiemae
I don't know the model number and can't move it. It is a Maytag Intellidry
#4 Posted : Tuesday, November 17, 2009 10:52:03 AM(UTC)
The name plate with a model number is usually on the door frame or on top of the control panel.
Dryer Will Not Run Unless Knob Is Held (Dryer Repair)
by Dixiedogs99 12/10/2017 5:41:06 PM(UTC)
Dryer will not run on no heat setting (Dryer Repair)
by rgarris1969 3/11/2017 6:59:15 PM(UTC)
Dryer will not run after changing plastic shims (Dryer Repair)
by Craig Lee 1/30/2017 4:09:05 AM(UTC)
Dryer Will not Run without manual turn of Drum (Dryer Repair)
by Cadman07 9/17/2015 6:58:08 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
Dryer will not run (Dryer Repair)
by kaostheory09 9/7/2014 1:04:46 PM(UTC)
Dryer will not run at all. (Dryer Repair)
by Kabbybarty 1/15/2014 6:34:36 PM(UTC)
Electric Roper Dryer will not run anymore (Dryer Repair)
by twsno 6/6/2013 4:12:17 PM(UTC)
whirlpool dryer will not run !!!!! (Dryer Repair)
by onestress 3/20/2012 6:39:02 PM(UTC)
Roper Dryer will not run (Dryer Repair)
by stevel75 2/26/2012 9:03:36 AM(UTC)
Electric Dryer will not run (Dryer Repair)
by nickfuhs 12/11/2011 1:04:29 PM(UTC)
Frigidaire dryer will not run (Dryer Repair)
by jchalfant 9/17/2010 5:57:01 AM(UTC)
by paula8315 7/17/2010 6:40:32 PM(UTC)
Dryer Will Not Run (Dryer Repair)
Belarus lamodj 7/12/2010 8:37:57 AM(UTC)
by pstulken 5/11/2010 7:06:53 AM(UTC)
