kaostheory09
#1 Posted : Sunday, September 7, 2014 1:04:46 PM(UTC)
kaostheory09
ok so the dryer does not spin... and when the door is open it will continue to emit heat, the element stays on, doesn't sound like the motor is trying to run at all ...
fairbank56
#2 Posted : Sunday, September 7, 2014 1:20:02 PM(UTC)
fairbank56
Groups: Expert
If heat does not come on in air only cycle, then your motor is bad.
Whirlpool 279827 Dryer Drive Motor - AppliancePartsPros.com
Eric
Dryer Will Not Run Unless Knob Is Held (Dryer Repair)
by Dixiedogs99 12/10/2017 5:41:06 PM(UTC)
Dryer will not run on no heat setting (Dryer Repair)
by rgarris1969 3/11/2017 6:59:15 PM(UTC)
Dryer will not run after changing plastic shims (Dryer Repair)
by Craig Lee 1/30/2017 4:09:05 AM(UTC)
Dryer Will not Run without manual turn of Drum (Dryer Repair)
by Cadman07 9/17/2015 6:58:08 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
Dryer will not run at all. (Dryer Repair)
by Kabbybarty 1/15/2014 6:34:36 PM(UTC)
Electric Roper Dryer will not run anymore (Dryer Repair)
by twsno 6/6/2013 4:12:17 PM(UTC)
whirlpool dryer will not run !!!!! (Dryer Repair)
by onestress 3/20/2012 6:39:02 PM(UTC)
Roper Dryer will not run (Dryer Repair)
by stevel75 2/26/2012 9:03:36 AM(UTC)
Electric Dryer will not run (Dryer Repair)
by nickfuhs 12/11/2011 1:04:29 PM(UTC)
Frigidaire dryer will not run (Dryer Repair)
by jchalfant 9/17/2010 5:57:01 AM(UTC)
by paula8315 7/17/2010 6:40:32 PM(UTC)
Dryer Will Not Run (Dryer Repair)
by lamodj 7/12/2010 8:37:57 AM(UTC)
by pstulken 5/11/2010 7:06:53 AM(UTC)
by MILTPD 5/5/2010 3:53:45 PM(UTC)
