Dryer has power as light comes on, but it does not run. When timer set no tick tick noise and it will not start.
A Model Number may help others help you !!! |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman A Model Number may help others help you !!! I don't know the model number and can't move it. It is a Maytag Intellidry
The name plate with a model number is usually on the door frame or on top of the control panel.
