Dieselista
#1 Posted : Saturday, October 7, 2023 9:06:22 AM(UTC)
Dieselista
United States
GE PFE28KELFDS bottom freezer, 4 years old. About a year or so ago I began to notice frost forming inside some frozen food packaging. Otherwise the freezer and reefer worked well and held temps. Run times for the compressor seem high but I understand this is normal for this model. Yesterday the freezer failed entirely, we found it at 40F. Reefer seemed to be working OK, holding a temp of 38-40F, but that may have just been delayed.
I unloaded the freezer, looked at the evap fan and evap coil, they looked OK, and there was no frost build up, the fan cycled periodically. I clean the condenser coils and fan religiously once a year, that deadline was about a month away, so I did it now, they weren’t especially dusty, but I cleaned them. As of last night, all seemed to be working, the freezer is back to 0
To +5F, I have it set at +5. Reefer at 38-40F, the set point. I see no frost on the evap coil, and the evap fan is running. I did a visual on the control board, nothing burned. As of just now the compressor and fans are off and the freezer and reefer have begun to warm again. I’m reluctant to reload the freezer. Is this indicative of a failing defrost T stat or defrost timer? I can use a multimeter.
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
by Guest 6/5/2024 11:24:33 AM(UTC)
Whirlpool Fridge GX5SHDXVA00 - Fridge Fine; Freezer Too Warm (Refrigerator & Freezer Repair)
by FamineLD 8/21/2023 4:54:57 AM(UTC)
Fridge too warm due to one of two air vents in the fridge section of a fridge freezer not working (Refrigerator & Freezer Repair)
by mungbeans 7/15/2023 1:08:45 PM(UTC)
Refrigerator freezer either too cold or too warm, running continually (Refrigerator & Freezer Repair)
by coolforcats 11/26/2022 3:15:56 PM(UTC)
GE ZISS42DCASS - Freezer too warm (Refrigerator & Freezer Repair)
by beb123 8/9/2022 12:55:43 PM(UTC)
FFHS2322MS9 - Freezer working, Fridge too warm (Refrigerator & Freezer Repair)
by Guest 8/9/2022 7:54:13 AM(UTC)
Amana Fridge Freezer and refrigerator too warm (Refrigerator & Freezer Repair)
by donc 4/9/2022 7:22:56 PM(UTC)
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3/1/2022 11:17:14 AM(UTC)
Frigidaire FRT17L3FW5 freezer too warm (Refrigerator & Freezer Repair)
by danielbraus 1/31/2022 10:38:31 AM(UTC)
Kenmore elite refrig freezer and fridge too warm (Refrigerator & Freezer Repair)
by glizotte 4/1/2021 10:01:46 AM(UTC)
Freezer Getting Too Warm (Refrigerator & Freezer Repair)
by Schmitty549 12/5/2020 6:36:50 PM(UTC)
Help with Off Refrigerator Electrolux too warm (Refrigerator & Freezer Repair)
by browntiger2 10/24/2020 10:50:02 AM(UTC)
Chest Freezer (Frigidaire) cycling up too warm? (Refrigerator & Freezer Repair)
by N6GQ 9/10/2020 8:20:18 AM(UTC)
GE pfs22sisdss fridge fine, freezer getting too warm (Refrigerator & Freezer Repair)
by erkme74 8/13/2020 4:16:29 PM(UTC)
KitchenAid Standalone Ice Maker Too Warm, No Ice (Refrigerator & Freezer Repair)
by tdominey 12/5/2019 9:08:34 AM(UTC)
