eric harron
#1 Posted : Friday, November 6, 2009 7:44:03 AM(UTC)
eric harron
i have a whirpool electric dryer that spins and runs but no heat! i have replaced the heating element and the thermostat Still NO heat plz help!!:confused: :confused: :confused:
#2 Posted : Friday, November 6, 2009 8:18:33 AM(UTC)
Replacement parts for WHIRLPOOL LER4634EQ2 | AppliancePartsPros.com
Here is the wiring diagram
Have you flipped the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually ripping the breaker. The heater requires the full 240 volts while the motor and timer will run on only half the line.
Better yet measure it with a meter. L1 to L2 should be 240 volts.
Could be the thermal heater's thermal fuse is blown.
This is the one on the heater Item 6 in Section 3.
If it is blown check to ensure you have good air flow out of the unit and the interior seals are good. Also clean/check your vent system.
You are actually pulling air over the heating coils, through the drum and then pushing it out the vent. The operating (cycling) thermostat is on the blower so if you are sucking in room air in the heater path to blower, it sees a cooler temperature and runs the heater hot.
jnelson1115@hotmail.com
#3 Posted : Wednesday, March 31, 2010 12:34:15 PM(UTC)
I have a Whirlpool Dryer, LER4634EQ2, that is running, but supplies no heat. I have tested the supply voltage at L1&L2 and on timer inputs and I am getting 248 volts. I have checked for continuity on heat element, high limit, thermal cut-off, dryer cycle thermostat, thermal fuse with a digital meter totally disconnected from all power and wire sources and each item checks out fine for continuity. However, on the cycle thermostat I have continuity except across the internal bias heater.
Can you tell me what the problem is?
#4 Posted : Saturday, April 3, 2010 5:12:43 AM(UTC)
Hope this message is received.
#5 Posted : Monday, April 5, 2010 2:08:30 AM(UTC)
Looks like I messed up on my earlier post.
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406688.pdf
[COLOR="Blue"]However, on the cycle thermostat I have continuity except across the internal bias heater.[/COLOR]
This should have no effect on getting heat though the drier will only provide high heat. I would double check this to be sure it is the internal heater that is open and not the thermostat contacts.
Set the unit at timed dry mid cycle and check that the TIMER SWITCH 2 contacts are closed.
If OK then all that is left is either a broken wire or the centrifugal switch on the motor.
You could attach (tape) one meter lead to L1 (black) on the timer then leave that lead there and then work your way back through the heater circuit. Component be component till you gat to the far side of the heater.
If all OK then all that is left is one of the wires to the centrifugal switch or the switch itself.
Note it could the the switch or the mechanism which closes it.
Though normally the motor will overheat if it is the mechanism as the Start/Run switch will also not activate leaving the start winding in circuit.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
