Replacement parts for WHIRLPOOL LER4634EQ2 | AppliancePartsPros.comHere is the wiring diagram
Replacement parts for WHIRLPOOL LER4634EQ2 | AppliancePartsPros.comHave you flipped the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually ripping the breaker. The heater requires the full 240 volts while the motor and timer will run on only half the line.
Better yet measure it with a meter. L1 to L2 should be 240 volts.
Could be the thermal heater's thermal fuse is blown.
This is the one on the heater Item 6 in Section 3.
If it is blown check to ensure you have good air flow out of the unit and the interior seals are good. Also clean/check your vent system.
You are actually pulling air over the heating coils, through the drum and then pushing it out the vent. The operating (cycling) thermostat is on the blower so if you are sucking in room air in the heater path to blower, it sees a cooler temperature and runs the heater hot.
