MontanaVike
#1 Posted : Tuesday, May 22, 2018 7:27:59 AM(UTC)
MontanaVike
Groups ready for retrieval: Registered
I have a Samsung dryer, model DV400EWHDWR. I keep blowing the fuse on the heater assembly. Each time I've replaced the fuse, I can get 1 or maybe 2 loads before it blows again.
I've tested the heater core and the thermostat and both work correctly (heater core heats up and has no contact with housing, thermostat turns off heat at about 170F and turns it back on at about 135F). I've replaced the fuse two times now so I'm pretty sure it wasn't just a bad fuse.
I'm wondering if it's my control board now. What do you think?
MontanaVike
#2 Posted : Wednesday, May 30, 2018 9:54:47 AM(UTC)
MontanaVike
I've now tested the 240v outlet and it tests fine. I've also replaced the fuse again which failed on the first load.
Anyone have an idea?
I'm thinking it's about time to get the repairman in.
MontanaVike
#3 Posted : Tuesday, June 12, 2018 9:33:47 AM(UTC)
MontanaVike
I'm still stumped by this.
I have now replaced the control board, all fuses, the thermostat and the thermistor. I have also replaced all the external ductwork and have reduced the run to about 8 feet with one 90 degree bend. The 90 degree is a smooth sheetmetal elbow.
Additionally, I have thoroughly cleaned the lint filter, the lint filter housing, the duct from the housing down to the blower and the blower itself. The only thing that I haven't cleaned is the bit of ducting that goes from the heater to the back of the drum. I'm not sure how to get to this without removing everything inside the dryer.
Does anyone have any ideas? I'm really close to cutting my losses and buying a new dryer which is not what I'd like to do!
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
samsung dryer Dv48H (Dryer Repair)
by Guest 2/27/2024 6:11:07 PM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung Dryer Test Mode (Dryer Repair)
by stanw 8/8/2023 2:36:51 PM(UTC)
Samsung Dryer possibly in flood throwing HC code (Dryer Repair)
by QuickPuppy 2/16/2023 7:41:27 AM(UTC)
Samsung dryer starts but won't turn drum or heat (Dryer Repair)
by coach_hall_42 1/22/2023 1:39:56 PM(UTC)
Samsung dryer stuck in continuous cycle (Dryer Repair)
by Guest 8/26/2022 6:18:39 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
Runs 3Min Stops-OR-Runs & Doesn't heat Samsung Dryer DV42H5000EW/A3-0000 (Dryer Repair)
by Guest 2/18/2022 11:57:14 AM(UTC)
Samsung dryer conversion to 50hz (Dryer Repair)
by Hlaudio 1/13/2022 2:57:31 AM(UTC)
Samsung dryer DV42H5200 still not heating after replacing all components (Dryer Repair)
by Guest 1/9/2022 11:26:52 AM(UTC)
Samsung Dryer HE error (Dryer Repair)
by hoagieh 10/23/2021 1:17:45 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
Samsung Dryer Error Code "HE" (Dryer Repair)
by czechmka 7/7/2021 11:01:22 AM(UTC)
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
