ajleitell
#1 Posted : Sunday, April 22, 2018 9:23:32 PM(UTC)
ajleitell
Rev. 12. Attempted to replace the Thrust Bearing, but the shaft is not long enough to accommodate the replacement pulley. The old thrust bearing works fine. I am not sure where to go next. The brake does not seem to disengage when the pulley is rotated counterclockwise.
GE top load washer doesn't spin (Washer Repair)
by marcobot 11/4/2020 6:47:00 PM(UTC)
Washer doesn't spin (Washer Repair)
by user21 12/8/2015 11:14:30 AM(UTC)
Recently moved washer doesn't spin (Washer Repair)
by lucymaud 3/10/2015 2:29:48 PM(UTC)
Top-loading GE washer doesn't spin (Washer Repair)
by BASSplayerACE 11/8/2014 6:28:44 AM(UTC)
Kenmore washer doesn't spin during wash cycle (Washer Repair)
by pcklbike 9/12/2014 2:20:03 PM(UTC)
Washer Doesn't spin (Washer Repair)
by Davejarm 6/19/2014 8:43:26 AM(UTC)
Maytag Atlantis Washer doesn't spin (Washer Repair)
by dave not the plumber 1/13/2014 5:17:05 PM(UTC)
GE Washer doesn't spin in spin cycle (Washer Repair)
by jglascoe1691 12/10/2013 10:22:42 AM(UTC)
Washer doesn't spin, burning smell (Washer Repair)
by PG_Chillin 10/3/2013 2:50:19 PM(UTC)
Whirlpool washer doesn't spin every load (Washer Repair)
by smitty731 5/31/2013 4:35:32 PM(UTC)
Washer doesn't spin - have all the sypmtoms (Washer Repair)
by MWarner 2/24/2013 7:42:26 AM(UTC)
Washer doesn't spin efficiently (Washer Repair)
by ffanslau 2/18/2013 1:03:30 PM(UTC)
Washer doesn't spin on high but spins on low (Washer Repair)
by WilliamC 9/17/2012 7:05:28 PM(UTC)
Washer doesn't spin or agitate (Washer Repair)
by dragz 7/28/2012 8:28:47 AM(UTC)
by bjorgvinben 6/28/2012 11:15:12 AM(UTC)
