Vonda Brashear
#1 Posted : Monday, January 8, 2018 6:35:30 AM(UTC)
Vonda Brashear
My dryer isn’t the same as the repair video when I put my model number in. Will the parts, heating element, thermistor etc, still be located in the same place?
ThatGuy
#2 Posted : Monday, January 8, 2018 1:14:59 PM(UTC)
ThatGuy
Groups: Expert
United States
Is your dryer a gas dryer?
If it is, those instruction and parts would be wrong. the video I watched was for an electric dryer.
I think part of your problem is you are missing some of your model number.
It should look more like this.
Model DV45H7000GW/A2-0000[URL="https://www.********************************.com/model-number/DV45H7000GWA20000/1482/0151200.html"][/URL]
Vonda Brashear
#3 Posted : Monday, January 8, 2018 4:43:53 PM(UTC)
Vonda Brashear
It’s an electric dryer, my panel is on top of the unit not in the front. That’s the only numbers/letters I saw for the model number but I’ll check it again. Also, that’s the same numbers/letters that’s on my manual that came with it.
Vonda Brashear
#4 Posted : Monday, January 8, 2018 4:58:59 PM(UTC)
Vonda Brashear
Ok I found the rest of the model number, put that in the parts finder spot, showed me the same parts available and the same video to do the repair for the thermistor. Guess I’ll just have to tear into it when my part arrives and see if they are in the same spots...
Vonda Brashear
#5 Posted : Tuesday, January 9, 2018 1:56:29 PM(UTC)
Vonda Brashear
So how fast is their shipping typically? I was expecting the part today but didn’t come.
ThatGuy
#6 Posted : Tuesday, January 9, 2018 3:02:27 PM(UTC)
ThatGuy
Groups: Expert
United States
I don't know. I only volunteer here to help people out. I don't get paid and I have no control over their shipping. Good luck.
Vonda Brashear
#7 Posted : Tuesday, January 9, 2018 7:06:59 PM(UTC)
Vonda Brashear
Thank you! I finally got thru to the customer service and thankfully my part is scheduled to arrive tomorrow! I appreciate the help!
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
samsung dryer Dv48H (Dryer Repair)
by Guest 2/27/2024 6:11:07 PM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung Dryer Test Mode (Dryer Repair)
by stanw 8/8/2023 2:36:51 PM(UTC)
Samsung Dryer possibly in flood throwing HC code (Dryer Repair)
by QuickPuppy 2/16/2023 7:41:27 AM(UTC)
Samsung dryer starts but won't turn drum or heat (Dryer Repair)
by coach_hall_42 1/22/2023 1:39:56 PM(UTC)
Samsung dryer stuck in continuous cycle (Dryer Repair)
by Guest 8/26/2022 6:18:39 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
Runs 3Min Stops-OR-Runs & Doesn't heat Samsung Dryer DV42H5000EW/A3-0000 (Dryer Repair)
by Guest 2/18/2022 11:57:14 AM(UTC)
Samsung dryer conversion to 50hz (Dryer Repair)
by Hlaudio 1/13/2022 2:57:31 AM(UTC)
Samsung dryer DV42H5200 still not heating after replacing all components (Dryer Repair)
by Guest 1/9/2022 11:26:52 AM(UTC)
Samsung Dryer HE error (Dryer Repair)
by hoagieh 10/23/2021 1:17:45 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
Samsung Dryer Error Code "HE" (Dryer Repair)
by czechmka 7/7/2021 11:01:22 AM(UTC)
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
