DANNA
#1 Posted : Monday, February 18, 2008 8:14:24 PM(UTC)
DANNA
My dishwasher has a water inlet on the outside of the tub, a hose runs from the water valve to this inlet and thru the side of the tub into the dishwasher. The inlet is v-shaped with the hose attaching on the top, it is open on both sides and looks to be molded as part of the tub, when I turn my dishwasher on ~ the water leaks out of one side of this inlet, I can also see 2 plastic pieces inside both of this openings. Could the valve be bad ????
#2 Posted : Tuesday, February 19, 2008 4:11:11 PM(UTC)
Hi Danna,
Possible there is an excessive pressure in the water line. Try to play with the water shut off valve under the sink to lower the pressure.
Here are the break down diagrams for the Whirlpool dishwasher Model DU980QPDB5
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 7:29:26 AM(UTC)
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 8/26/2015 9:53:11 AM(UTC)
Kitchen aid Dishwasher Leaks from door at start up (Dishwasher Repair)
by AmericanRosie 4/12/2013 3:48:48 PM(UTC)
dishwasher leaks when running (Dishwasher Repair)
by husker69 8/29/2012 10:24:55 AM(UTC)
dishwasher leaks in bottom center (Dishwasher Repair)
by leonak 6/20/2012 5:23:06 PM(UTC)
Frigidaire Dishwasher Leaks Hours After Cycle (Dishwasher Repair)
by barnold99 5/23/2012 6:54:22 PM(UTC)
Kenmore Dishwasher leaks above motor (Dishwasher Repair)
by stlawerence 5/14/2012 4:08:32 PM(UTC)
roper dishwasher leaks from under door (Dishwasher Repair)
by e.. 1/10/2012 11:19:47 AM(UTC)
Maytag Quiet Series 200 dishwasher leaks (Dishwasher Repair)
by Ariail 1/7/2012 7:18:22 AM(UTC)
dishwasher leaks intermittently (Dishwasher Repair)
by macmom 12/24/2011 5:12:25 PM(UTC)
Amana Dishwasher leaks from above motor pump assembly (Dishwasher Repair)
by oakland1000 11/9/2011 1:00:39 PM(UTC)
Dishwasher leaks down float tube (Dishwasher Repair)
by chrisjs 11/4/2011 12:05:33 PM(UTC)
Dishwasher Leaks (Dishwasher Repair)
by ms1145 10/21/2011 2:11:52 PM(UTC)
dishwasher leaks from bottom (Dishwasher Repair)
by jasonkk 9/30/2011 4:38:56 PM(UTC)
