Kitchenaid dishwasher model #KUDS25HBLI leaks intermittently. Any thoughts?
Leak from the door or out the bottom?
Originally Posted by: ApplianceJunk  Leak from the door or out the bottom? from the door
Then it's simply a matter of removing the front door panel and look for the leak. I often find a loose screw or two for the dispenser assembly.
