I had to take apart as the dishwasher was not draiing and was full of hardwater deposits found the problem was the outlet plugged. I had taken the pump apart and cleaned it when put together it drains great but leaking out bottom around the motor. Do I need to replace all seals / gaskets that inside or just motor to tub gasket even though I did not take it apart? Thanks
Originally Posted by: husker69  I had to take apart as the dishwasher was not draiing and was full of hardwater deposits found the problem was the outlet plugged. I had taken the pump apart and cleaned it when put together it drains great but leaking out bottom around the motor. Do I need to replace all seals / gaskets that inside or just motor to tub gasket even though I did not take it apart? Thanks my dishwasher SHU 5000 leaks , what could be the probable cause
