husker69
#1 Posted : Wednesday, August 29, 2012 10:24:55 AM(UTC)
husker69
I had to take apart as the dishwasher was not draiing and was full of hardwater deposits found the problem was the outlet plugged. I had taken the pump apart and cleaned it when put together it drains great but leaking out bottom around the motor. Do I need to replace all seals / gaskets that inside or just motor to tub gasket even though I did not take it apart?
SKG333
#2 Posted : Monday, October 22, 2012 2:54:59 PM(UTC)
SKG333
my dishwasher SHU 5000 leaks , what could be the probable cause
