Vendrasco
#1 Posted : Saturday, September 2, 2017 1:41:12 PM(UTC)
Vendrasco
I have a maytag top load. All sudden mid cycle the motor would only hum in spin. I have disconnect the belt and ran just the motor and it still just hums. So that eliminates mechanical prob. I have replaced the motor thinking it was the windings or brushes, still hums so not the motor. The lid switch works the timer functions as it should cycle wise. The outlet has 120v. The harness is in mint shape. No visible wear or burns. If When the motors humming if I grab the belt and just give it a little pull the motor will run, just won't start on its own.
Any ideas what it could be?
Top load Amana won't drain, motor just hums (Washer Repair)
by row2 11/22/2016 2:50:35 PM(UTC)
motor just hums (Dishwasher Repair)
by jeffbigney 2/18/2016 4:45:22 PM(UTC)
Frigidaire laundry center washer motor just hums for 5 seconds and shuts off (Washer Repair)
by rtlind83 3/8/2013 2:07:34 PM(UTC)
White-Westinghouse washer - The motor just hums (Washer Repair)
by mikopiko 3/22/2012 7:26:22 PM(UTC)
new coupler, now motor just hums (Washer Repair)
by joni41 3/3/2010 11:37:05 AM(UTC)
Dryer motor just hums (Dryer Repair)
by Pottspd 3/8/2009 7:04:34 AM(UTC)
