I just replaced the icemaker flapper assembly to fix ice dispenser freezeup problem. there are about 10 electrical tab connectors on back side of push button switches for lock/crushed/cubes/light/etc. I market the connectors with numbers before disassemble but unfortunately some of the number got rubbed off! I was able to put it back together with I think all the connectors going to the right tabs - lock and unlock seem to work correctly, light on/off seems to work correctly, and crushed ice seems to work correctly. The only thing not working is the cube ice, which I think requires the rotor shaft inside ice bucket to rotate when button is pushed to move ice out. This is not happening. The rotor shaft appears to move normally when crushed ice button is pushed. It seems like if everything else is working then I must have the connectors on the correct tabs, but maybe did something wrong with the cube ice connectors. Any thoughts? Thanks
