frankkohn
#1 Posted : Monday, June 26, 2017 2:05:11 PM(UTC)
frankkohn
I just replaced the icemaker flapper assembly to fix ice dispenser freezeup problem. there are about 10 electrical tab connectors on back side of push button switches for lock/crushed/cubes/light/etc. I market the connectors with numbers before disassemble but unfortunately some of the number got rubbed off! I was able to put it back together with I think all the connectors going to the right tabs - lock and unlock seem to work correctly, light on/off seems to work correctly, and crushed ice seems to work correctly. The only thing not working is the cube ice, which I think requires the rotor shaft inside ice bucket to rotate when button is pushed to move ice out. This is not happening. The rotor shaft appears to move normally when crushed ice button is pushed. It seems like if everything else is working then I must have the connectors on the correct tabs, but maybe did something wrong with the cube ice connectors. Any thoughts? Thanks
Kenmore Icemaker not working (Refrigerator & Freezer Repair)
by belize2020 6/7/2013 3:27:07 PM(UTC)
Kenmore icemaker (Refrigerator & Freezer Repair)
by ytrehguad-504 7/10/2012 8:37:58 AM(UTC)
Kenmore icemaker fill tube freezing (Refrigerator & Freezer Repair)
by Duinan 7/3/2012 4:10:57 PM(UTC)
Kenmore icemaker does not eject (Refrigerator & Freezer Repair)
by padredw 1/30/2012 1:18:00 PM(UTC)
Kenmore Icemaker Leaking (Refrigerator & Freezer Repair)
by wildesrr 4/26/2011 8:35:41 AM(UTC)
Kenmore icemaker door wont close (Refrigerator & Freezer Repair)
by dgam 9/16/2010 7:01:25 AM(UTC)
Replaced Kenmore icemaker - it won't fill with water (Refrigerator & Freezer Repair)
by jhlee14 9/16/2009 4:45:30 AM(UTC)
Kenmore Icemaker stopped working (Refrigerator & Freezer Repair)
by coaster 9/8/2009 8:01:53 AM(UTC)
Kenmore Icemaker overflow water (Refrigerator & Freezer Repair)
by Sam88 7/28/2009 8:23:26 AM(UTC)
Kenmore Icemaker Problems? (Refrigerator & Freezer Repair)
by mtmiller92 7/2/2008 2:39:07 PM(UTC)
Kenmore icemaker and water dispenser problems (Refrigerator & Freezer Repair)
by jenlow 5/26/2008 12:41:26 PM(UTC)
by nuke guy 9/18/2007 4:01:53 AM(UTC)
