Wabasmstr
#1 Posted : Friday, June 16, 2017 4:05:54 PM(UTC)
Wabasmstr
I've replaced the fuse, limit switches, thermostat and had a parts house test the heater could. Has air but still no heat. Tested continuity on all parts. All are good. Any ideas what to do next?
brobriffin
#2 Posted : Friday, June 16, 2017 4:52:29 PM(UTC)
brobriffin
Man
United States
1. test for actual 240 volts across L1 and L2 at the terminal block
2. check to see if the centrifugal switch on the motor is passing 120 volts to the heating element
Guest
#3 Posted : Friday, September 17, 2021 6:50:45 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Dryer gets hot, stays hot will not time to cool off. Could the problem be a high temperature thermostat?
Guest
#4 Posted : Friday, September 17, 2021 6:52:05 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
