Ohallorans
#1 Posted : Monday, August 8, 2016 1:38:09 AM(UTC)
Ohallorans
Icemaker not making ice. Water running in a stedy stream into the tray but no ice is being made.
GeneC2
#2 Posted : Monday, August 8, 2016 11:58:38 AM(UTC)
GeneC2
You will need to provide more information. Was this sudden or gradual, Is compressor and condenser fan running, what are storage comp. temps, etc. There are too many variables that need to be narrowed down. Check the condenser coils for dust build up if everything is running and clean them if they are clogged, also feel the suction side tube about 6 inches from compressor, it should feel cold and the line to condenser should be hot. If this is not the case then it's either a sealed system problem or a control board issue. Either way please provide more info.
Ice maker doesn't make ice (Refrigerator & Freezer Repair)
by db98 1/7/2012 9:46:03 AM(UTC)
Ice Maker doesn't make Ice (Refrigerator & Freezer Repair)
by GordonH 2/1/2011 12:49:54 PM(UTC)
Refrigerator doesn't make ice or dispense water (Refrigerator & Freezer Repair)
by Sam6 9/22/2010 12:41:16 PM(UTC)
ice maker doesn't make ice? (Refrigerator & Freezer Repair)
by mikeandcarolegill 7/11/2010 11:17:08 AM(UTC)
Ice maker doesn't make ice. (Refrigerator & Freezer Repair)
by dorisanddale 6/1/2010 11:33:55 AM(UTC)
Ice Maker doesn't make ice, just water everywhere (Refrigerator & Freezer Repair)
by mpro 6/10/2009 10:09:50 AM(UTC)
