dorisanddale
#1 Posted : Tuesday, June 1, 2010 11:33:55 AM(UTC)
dorisanddale
I can not tell you the model number right now but I'll tell you what in wrong. It's a side by side. There is no water entering the icemaker but the water valve works and the water flows to the icemaker. What I did was replace the cooling fan for the condenser so i unpluged the water valve so i could get to it easier. After that the ice maker quit making ice but the fins in the icemaker kept turning. what do I need to do to start the icemaking cycle again. Thanks, dorisanddaqle
dorisanddale
#2 Posted : Wednesday, June 2, 2010 10:15:45 AM(UTC)
dorisanddale
Originally Posted by: dorisanddale Go to Quoted Post
the model number is GS2SHAXNL00 . tell you what in wrong. It's a side by side. There is no water entering the icemaker but the water valve works and the water flows to the icemaker. What I did was replace the cooling fan for the condenser so i unpluged the water valve so i could get to it easier. After that the ice maker quit making ice but the ice ejectors in the icemaker kept turning. Now the ejector quit turning. I had instructions on how to use a jumper on the icemaker and it restarted it before but i misplaced them. If i did this and it still didn't work what would be my next step. Also could tell me where i can get new instructions or could you tell me how. Thanks dorisanddale My e-mail address is: dorism59@charter.net
#3 Posted : Wednesday, June 2, 2010 6:05:39 PM(UTC)
1/ ...i unpluged the water valve so i could get to it easier. After that the ice maker quit making ice but the ice ejectors in the icemaker kept turning...
2/...I had instructions on how to use a jumper on the icemaker and it restarted it before but i misplaced them...
1/ I would double check all wires connected to the water valve.
2/ What did you misplace and how?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GS2SHAXNL00 Refrigerator | AppliancePartsPros.com
