I can not tell you the model number right now but I'll tell you what in wrong. It's a side by side. There is no water entering the icemaker but the water valve works and the water flows to the icemaker. What I did was replace the cooling fan for the condenser so i unpluged the water valve so i could get to it easier. After that the ice maker quit making ice but the fins in the icemaker kept turning. what do I need to do to start the icemaking cycle again. Thanks, dorisanddaqle
Originally Posted by: dorisanddale  the model number is GS2SHAXNL00 . tell you what in wrong. It's a side by side. There is no water entering the icemaker but the water valve works and the water flows to the icemaker. What I did was replace the cooling fan for the condenser so i unpluged the water valve so i could get to it easier. After that the ice maker quit making ice but the ice ejectors in the icemaker kept turning. Now the ejector quit turning. I had instructions on how to use a jumper on the icemaker and it restarted it before but i misplaced them. If i did this and it still didn't work what would be my next step. Also could tell me where i can get new instructions or could you tell me how. Thanks dorisanddale My e-mail address is: dorism59@charter.net
Originally Posted by: dorisanddale  1/ ...i unpluged the water valve so i could get to it easier. After that the ice maker quit making ice but the ice ejectors in the icemaker kept turning...
2/...I had instructions on how to use a jumper on the icemaker and it restarted it before but i misplaced them... 1/ I would double check all wires connected to the water valve. 2/ What did you misplace and how? Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GS2SHAXNL00 Refrigerator | AppliancePartsPros.comGene.
