Utilaken
#1 Posted : Sunday, May 15, 2016 10:26:31 AM(UTC)
Utilaken
Hello to all: My refrigerator now is making condensation on the frige side, glass shelves. On this model inside on the upper left wall/ corner seems to be an air filter, this has some ice on the outside plastic housing. When I removed the 3 crisper drawers, the 3rd one from the bottom has some sort of housing on the left wall ,looks like an air supply of some sort, this had a decent size piece of ice on it as well... Can anyone direct me on this particular model as where to start to diagnose the problem ? I don't even know where the drain hole is on this unit.... We live on a very small island with no techs or serviceman.
Thank you all! in advance with any advice or suggestions on this particular side by side model.
Ken H
DannyDeuce
#2 Posted : Wednesday, May 18, 2016 11:26:19 AM(UTC)
DannyDeuce
I recommend take pictures of everything you mentioned in you post and post them on here. Will make it a lot easier for us to follow.
Utilaken
#3 Posted : Wednesday, May 18, 2016 11:48:49 AM(UTC)
Utilaken
Thx Danny, I just figured it out, the door gasket "on the bottom" of the frige door was not in it's "groove" thus allowing in heat/humidity.
Utilaken
#4 Posted : Tuesday, November 8, 2016 5:50:38 AM(UTC)
Utilaken
sorry, posted this in wrong section, maybe a moderator can delete as I already reposted in the correct area.. THX
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Need help with diagnosis - bake and broil not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/7/2022 6:29:02 AM(UTC)
Frigidiare Gallery High temp alert. Need help troubleshooting. (Refrigerator & Freezer Repair)
by GregWood 8/28/2022 7:47:25 PM(UTC)
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
need help with model number (Oven Repair (including Ranges and Cooktops))
by onadraw 7/2/2021 10:01:12 AM(UTC)
Need Help With Frigidaire FGHS2631PF4A (Refrigerator & Freezer Repair)
by BrianR1 3/2/2021 1:46:20 PM(UTC)
I need help with literary work (General Talk)
by Fackbey201350 4/17/2020 7:36:42 AM(UTC)
GE WASHER NEED HELP(SOLVED) (Dishwasher Repair)
by Covenant29204 9/8/2019 9:51:57 AM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 1/28/2019 2:06:26 PM(UTC)
