Lou Pine
#1 Posted : Tuesday, April 19, 2016 2:36:23 AM(UTC)
Lou Pine
A freezer that was given to me will not power up. Light comes on correctly. No compressor start. I removed power line going to relay and connected it directly to 110v. Compressor starts and runs to freezing.
Replugged refrig power line back into relay. No start.
Initial Display reading o of ff f and repeat..
Pressing any buttons have no effect on start or display
Pressed and held control lock key for 5 seconds
Display: o of ff f lo ff f...
Press control lock key again: lo ff f ul o of ff f o of ff f ..
Pressing control lock again--repeats pattern.
Is ul or lo a fault code or is this board melba toast?
If board is bad should thermistor be replaced also-as a set?
Appliance Medics
#2 Posted : Tuesday, April 19, 2016 3:27:58 AM(UTC)
Appliance Medics
I've seen that same control go bad multiple times giving the same complaint you have I'd say you need a new one.
kenmore deep freezer not turning on or clicking (Refrigerator & Freezer Repair)
by josh39026 3/23/2015 6:25:06 PM(UTC)
Chest freezer not turning on fully (Refrigerator & Freezer Repair)
by Mlesch 6/18/2014 8:19:03 PM(UTC)
Refrigerator & Freezer not turning on (Refrigerator & Freezer Repair)
by derry163 10/28/2012 6:21:45 PM(UTC)
