A freezer that was given to me will not power up. Light comes on correctly. No compressor start. I removed power line going to relay and connected it directly to 110v. Compressor starts and runs to freezing. Replugged refrig power line back into relay. No start. Initial Display reading o of ff f and repeat.. Pressing any buttons have no effect on start or display Pressed and held control lock key for 5 seconds Display: o of ff f lo ff f... Press control lock key again: lo ff f ul o of ff f o of ff f .. Pressing control lock again--repeats pattern. Is ul or lo a fault code or is this board melba toast? If board is bad should thermistor be replaced also-as a set?
I've seen that same control go bad multiple times giving the same complaint you have I'd say you need a new one.
