genot
#1 Posted : Thursday, December 17, 2015 1:41:42 PM(UTC)
genot
My dishwasher was not unlocking when I pressed the heated dry botton and would not reboot after shutting off power for over a minute. I changed the control asm out and when I turned the power on the number 99 appeared by the on/off botton and then the machine ran through an entire cycle. After the cycle the machine beeped and all the green lights came on and have stayed on for over 24 hrs. There was no response when I tried to unlock by pressing heated dry and when I powered off and on all the green lights came back on and the machine is no responding at all. Any suggesting or ideas on what's going on would be greatly appreciated!
Genot
Dishwasher control assembly Electolux Frigidaire (Dishwasher Repair)
by inez 9/22/2019 2:22:11 PM(UTC)
GE Washer Won't Start - Control Assembly? (Washer Repair)
by pittmonkey 7/7/2015 7:29:18 AM(UTC)
GE Dishwasher Control Assembly Replacement (Dishwasher Repair)
by jpatl 4/16/2013 5:47:32 PM(UTC)
Charred module control assembly harness (Dishwasher Repair)
by EEguy60 3/21/2013 9:11:03 AM(UTC)
module control assembly ? (Dishwasher Repair)
by djw61 10/5/2012 10:24:41 AM(UTC)
Replace Electronic Control Assembly? (Dishwasher Repair)
by rhow 3/9/2012 5:05:59 AM(UTC)
Dishwasher electronic control assembly did not fix problem (Dishwasher Repair)
by dpw-ct 1/17/2012 1:52:12 PM(UTC)
Control Assembly reset (Washer Repair)
by mjsears 7/11/2011 12:12:09 PM(UTC)
Water from broken inlet valve soaked control assembly circuit board on GE washer (Washer Repair)
by Smoke House Willie 12/22/2010 7:03:01 PM(UTC)
How to replace Jenn-Air touchpad control assembly (Oven Repair (including Ranges and Cooktops))
by rzidle@verizon.net 9/12/2010 4:13:19 PM(UTC)
by ladyjane 8/26/2010 4:30:13 AM(UTC)
Electronic control assembly replacement (Dishwasher Repair)
by materman 5/24/2010 7:53:41 AM(UTC)
maytag, control assembly (Refrigerator & Freezer Repair)
by davet6430 3/13/2010 7:34:08 AM(UTC)
GE Washer Control Assembly (Washer Repair)
by kkstout 7/25/2009 5:33:33 AM(UTC)
replacing motor control assembly (Washer Repair)
by cbrickley 4/24/2009 3:49:57 AM(UTC)
