My dishwasher was not unlocking when I pressed the heated dry botton and would not reboot after shutting off power for over a minute. I changed the control asm out and when I turned the power on the number 99 appeared by the on/off botton and then the machine ran through an entire cycle. After the cycle the machine beeped and all the green lights came on and have stayed on for over 24 hrs. There was no response when I tried to unlock by pressing heated dry and when I powered off and on all the green lights came back on and the machine is no responding at all. Any suggesting or ideas on what's going on would be greatly appreciated!
Genot
