idler pulley froze,stoped dryer...repaired pulley...dryer won't start,...timer was an issue-not accurate ,replaced....replaced control board (guess),available rebuilt...power up ..start button works,timer will run for 5-10 sec. then stop...tested drum motor,door switch,thermal fuse,all good,...am I missing anything ?many thanks for any help-idea.....Patrick...e-mail ...mk2jag@att.net
