my Kenmore gas dryer will ignite and then shut off after about 15/20 seconds. I have replaced the coils and checked continuity on the thermal fuse, thermostats in the back. I also checked for lint blockage ( none). The igniter appears to be okay as does the flame sensor, checked for continuity on both. Not sure where to go from here.
