Troiubleshooting to date: Continuity checks Thermal fuse: ok Thermal cutout: ok Gas valve solenoids 3 prong - ok, 2 prong - open Replaced both gas solenoids. Igniter will glow, burner lights, dryer warms, but then cools relatively quickly. I assume the burner is going out. I've since checked flame sensor continuity - ok Below is what i have been following. Seems like I have done all the troubleshooting which seems ok, but its still not working. Ideas? http://www.********************...2601-Kenmore-Dryer-Parts
try testing the cycling thermostat
Well not sure what is going on - but I checked continuity on the cycling thermostat and it was ok. Tried running the dryer again and it seemed to be working and continuous heat flowing from the exhaust. Put everything back together and ran a cycle with clothes and it seems now to be working ok. A little stumped - as I did find a bad gas solenoid but after replacing still was not working correctly. I will continue to try and report back any new issues. Keeping fingers crossed ...
