ed
edward boyko
#1 Posted : Sunday, August 30, 2015 7:59:51 AM(UTC)
edward boyko
ref temp flashing. shut off breaker for one min. temp showed 64 degrees cleaned back of ref. found air not circulating on ref. side. taped back of ref heard fan come on making noise coming on and off temp came down to 38 degrees. then temp light started flashing again
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
OLD FRIDGEDAIRE OVER & UNDER GLRT214RAW4 (Refrigerator & Freezer Repair)
by brou102 6/29/2024 10:51:20 AM(UTC)
Bosch sprayer channel clip spot weld failed on back wall (Dishwasher Repair)
by Billymons 6/15/2024 5:23:17 AM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Water tube disconnected (Refrigerator & Freezer Repair)
by Guest 5/31/2024 11:41:13 AM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 5/20/2024 7:30:54 AM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
