Marvin Family
#1 Posted : Sunday, July 12, 2015 12:15:49 PM(UTC)
Marvin Family
Our washer will not drain and it's not filling with any water.... Could this be electronic?? Or did both valves and pumps break at the same time?
Please help
Thank you!!
sidfink43
#2 Posted : Monday, July 13, 2015 6:40:10 AM(UTC)
sidfink43
Take a look at the tech notes that should be under the top or inside the lower service panel and see if you can put it into a diagnosiic mode and generate some error codes.
These Duet machines are very hard to diagnose, even for Whirlpool techs. Concentrate on the door lock assembly, the wiring from the door lock assembly to the control unit, the control unit and the motor control unit.
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Maytag Bravos MCT HELP!!!!! (Washer Repair)
by Guest 10/23/2021 7:31:14 AM(UTC)
help!!!! (Refrigerator & Freezer Repair)
by sunni1200 11/29/2016 2:23:52 PM(UTC)
Please HELP!!! My dryer is not heating. (Dryer Repair)
by Anonpirate 7/28/2016 11:44:39 PM(UTC)
Gibson Gwt 645rhs0 Help!!! (Washer Repair)
by slotch69 7/31/2015 10:10:54 AM(UTC)
Please help!!!! Gas oven temp issue (Oven Repair (including Ranges and Cooktops))
by volfan54 7/22/2015 5:19:00 PM(UTC)
obscure small commercial cooler NEED HELP!!! (Refrigerator & Freezer Repair)
by soliddrummer 3/18/2015 8:41:40 PM(UTC)
Help!!! Washer tub trying to escape!!! (Washer Repair)
by Meredith3356 2/16/2015 2:42:31 PM(UTC)
Please Help!!!!!! (Microwave Repair)
by TheFreedMind 3/16/2014 11:21:27 PM(UTC)
Freezer Help!!! (Refrigerator & Freezer Repair)
by rizzo692 2/21/2014 12:34:31 PM(UTC)
Nothing Is Ever Easy! Help!!! (Oven Repair (including Ranges and Cooktops))
by jaylek12 1/4/2014 4:54:06 PM(UTC)
HELP!!! Hot in Georgia (Heating, Ventilation, and Air Conditioning (HVAC))
by Chris311L 11/18/2013 3:38:51 PM(UTC)
HELP!!! GE Side by side coils freezing up (Refrigerator & Freezer Repair)
by billda 5/14/2013 4:42:45 AM(UTC)
Samsung washer 2e error, help!!! (Washer Repair)
by mikehook 3/21/2013 12:00:52 PM(UTC)
Viking Cooktop Conversion to LP (Help!!!) (Oven Repair (including Ranges and Cooktops))
by hareira 12/21/2012 4:49:35 PM(UTC)
