amya33
#1 Posted : 10 years ago
amya33
My dryer spins but there is no heat. I dont own an Ohm meter to check continuity but i replaced the thermal fuse. After starting it up, the fuse immediately blew. Any thoughts what i should look at next? Why would a brand new fuse have blown?
#2 Posted : 10 years ago
A model number would be helpful.
Find your model number - AppliancePartsPros.com
A fuse would blow right away if you have a dead short in the unit.
Note that I am not sure you are using the correct terminology.
What is normally called the thermal fuse kills power to the motor.
Could be you replaced the thermal cut-off or the high limit thermostat.
They effect only the heat.
I would unplug the unit and check the heat coil.
Disconnect both wires from the heater and measure across the heater.
Should be in the 8 to 12 ohm range.
Now check from each side of the heater to it's case.
Both should be infinite ohms.
If not the heater is grounded and should be replaced.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
amya33
#3 Posted : 10 years ago
amya33
Thank you for the quick reply denman. The model number is KGYS700GQ1. The part i ordered was 3392519 (thermal fuse). I am borrowing a neighbors Ohm meter today so hopefully i can pinpoint exactly where the issue is instead of ordering part i think it the solution just to have it blow. My next question is if the issue is the heating coil or element am i better off just purchasing a new dryer? Thank you.
#4 Posted : 10 years ago
Parts for KitchenAid KGYS700GQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Your unit is a gas unit so the fuse you replaced will just shut off the heat.
There is nota heating element in the unit.
File Attachment(s):
KGYS700.pdf (236kb) downloaded 3 time(s).
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 2 years ago
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 3 years ago
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 4 years ago
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 4 years ago
GE Dryer not heating up (Dryer Repair)
by Dryernoob 5 years ago
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 5 years ago
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 6 years ago
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 7 years ago
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 7 years ago
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 7 years ago
Dryer not heating (Dryer Repair)
by hoymanj 7 years ago
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 8 years ago
Maytag dryer not heating (Dryer Repair)
by Jmr721 8 years ago
Amana Dryer not heating (Dryer Repair)
by HnRmom 8 years ago
by tcdegener@yahoo.com 8 years ago
