Just replaced the limiter fuse and heater assembly/thermostat but still not heating up. Dryer runs okay but no heat. I need help. Thank you
Here are your parts Parts for Frigidaire AEQ8700FE0 Dryer - AppliancePartsPros.comHere is the tech sheet. http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdfDid you check the parts to determine that they were bad before replacing them or did you just replace them? Have you checked the power. The heater requires the full 240 volts. Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"]Be careful as 240 volts is lethal !!![/COLOR] |
THIS FORUM IS DEAD!!!!!!! |
