Elarde
#1 Posted : Thursday, June 18, 2015 1:17:00 AM(UTC)
Elarde
Just replaced the limiter fuse and heater assembly/thermostat but still not heating up. Dryer runs okay but no heat. I need help. Thank you
#2 Posted : Thursday, June 18, 2015 2:37:04 AM(UTC)
Parts for Frigidaire AEQ8700FE0 Dryer - AppliancePartsPros.com
Here is the tech sheet.
http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdf
Did you check the parts to determine that they were bad before replacing them or did you just replace them?
Have you checked the power.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
Gas dryer runs but no heat. (Dryer Repair)
by peter g 1/7/2011 9:32:32 PM(UTC)
Roper,dryer runs but no heat. (Dryer Repair)
by JOE BLACK 9/19/2009 1:39:36 PM(UTC)
