muffins80
#1 Posted : Friday, June 12, 2015 3:20:59 PM(UTC)
muffins80
Hello, was hoping to get a little help from you guys. I bought this dryer a couple of years back and it's been pretty good. HEre's what's transpired.
Last week - quit heating, I put in a new cycling thermostat and thermal fuse (non oem) It worked for about 5 loads.
Today - Figuring the cheap non oem parts failed I put in FSP branded cycling switch and thermal fuse. still no heat.
Things I checked today.
1. Cycling thermostat
2. Thermal fuse
3. High limit thermostat
4. High limit non resettable fuse
5.Heater element - 60 ohms
6. Voltage coming in to unit; has proper 120v on each leg to neutral and 240 on L1 to L2
7. Checkecd continuity on timer from blk to red for heat and was good.
So what should I check next? Thanks for any and all help. I'm an auto technician by trade and checking things via 120-240 from wiring diagrams is a little harder for me. ( used to 12 volt negative ground)
muffins80
#2 Posted : Friday, June 12, 2015 3:44:46 PM(UTC)
muffins80
Put an old element in and it went to working!
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
