Judy Kramer
#1 Posted : Tuesday, April 7, 2015 8:17:21 AM(UTC)
Judy Kramer
ice appears on bottom of refrigerator under deli drawel
Jeff / APP Team
#2 Posted : Wednesday, April 8, 2015 6:05:31 AM(UTC)
Jeff / APP Team
Hello Judy. You will need to install a evap drain probe and a seal kit into the unit. Check out the attachment on this post.
To do this, Disassemble the Cap. Disassemble the Top Table. Disassemble the water supply connector. Re-assemble after tucking up water supply hose with foam seal (W30mm*L50mm*T3mm). No gap allowed. Tuck up whole area of hose with foam seal (W50mm*L80mm*T5mm). Make sure it is tight.
At the water tank, Tuck up inlet and outlet of the water hose with OJC seal
(W40mm*L80mm*T5mm), and then reassemble. The sealed hose should be inserted into the hole located inside of the liner.
Install the drain clip on the heater. Make sure the probe goes into the drain hole. Clean out the drain on the unit.
On the evap cover, Remove the evaporator cover. Check for condensation:
A. On the fan motor case
B. On the back of the
evaporator cover
aluminum plate
C. Behind the drain plate.
Remove the aluminum tape on the drain pan.
Remove 4 screws in the case of the fan motor, and then remove the motor and shroud assembly.
Be careful not to damage the tape.
Attach the foam strip with the center hole onto the Styrofoam as shown.
Reassemble evaporator cover.
Attach foam seal (W15mm) to bottom of evaporator cover.
Part number: AP5646574
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
