Judy Kramer
#1 Posted : Tuesday, April 7, 2015 8:17:21 AM(UTC)
Judy Kramer
ice appears on bottom of refrigerator under deli drawel
Jeff / APP Team
#2 Posted : Wednesday, April 8, 2015 6:05:31 AM(UTC)
Jeff / APP Team
Hello Judy. You will need to install a evap drain probe and a seal kit into the unit. Check out the attachment on this post.
To do this, Disassemble the Cap. Disassemble the Top Table. Disassemble the water supply connector. Re-assemble after tucking up water supply hose with foam seal (W30mm*L50mm*T3mm). No gap allowed. Tuck up whole area of hose with foam seal (W50mm*L80mm*T5mm). Make sure it is tight.
At the water tank, Tuck up inlet and outlet of the water hose with OJC seal
(W40mm*L80mm*T5mm), and then reassemble. The sealed hose should be inserted into the hole located inside of the liner.
Install the drain clip on the heater. Make sure the probe goes into the drain hole. Clean out the drain on the unit.
On the evap cover, Remove the evaporator cover. Check for condensation:
A. On the fan motor case
B. On the back of the
evaporator cover
aluminum plate
C. Behind the drain plate.
Remove the aluminum tape on the drain pan.
Remove 4 screws in the case of the fan motor, and then remove the motor and shroud assembly.
Be careful not to damage the tape.
Attach the foam strip with the center hole onto the Styrofoam as shown.
Reassemble evaporator cover.
Attach foam seal (W15mm) to bottom of evaporator cover.
Part number: AP5646574
GE Refrigerator DFE29JSDASS (Dishwasher Repair)
by DOUGZARA 4/24/2024 9:43:25 AM(UTC)
Electrolux Refrigerator not getting cold (Refrigerator & Freezer Repair)
by jesus freak 3/30/2024 1:11:55 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
