AHOLLAWAY78
#1 Posted : 10 years ago
AHOLLAWAY78
I have a GE glasstop stove and when I went to turn oven on heard a loud pop and the oven nor display is working at all but the stove top is working im not sure where to start looking for the problem
#2 Posted : 10 years ago
Start by trying to find out what/where the pop was.
There may be some scorching or a weld/arc mark.
I would start by unplugging the unit and checking along the oven elements to see if the ceramic coating on one of them has blown out.
Next remove the back and check the wiring to/from the elements.
Then check inside the control console.
Odds are that the electrical spike that would accompany the pop also blew the control board so you may have a couple parts to replace.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 8 months ago
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 8 months ago
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 9 months ago
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 9 months ago
Recommend gas range single oven (General Talk)
by 007noob 9 months ago
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 9 months ago
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 9 months ago
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 9 months ago
NEITHER OVEN NOR BROIL BURNER LIGHTS (Oven Repair (including Ranges and Cooktops))
by roastbredfruit 9 months ago
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 10 months ago
Frigidaire oven issue (Dishwasher Repair)
by Guest 10 months ago
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 10 months ago
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 10 months ago
Samsung Range Overheating Oven (Oven Repair (including Ranges and Cooktops))
by ajerwin 10 months ago
